Parking Lights/Alarm question
Old Nov 18, 2001 | 09:00 PM
camaro 22's Avatar
OK, I have the same alarms, installed by the same people in my two camaros and on the one the parking lights flash when i disarm/arm it or it goes off, and on the other they don't do anything. The installer said it was the brain the one that wasn't working for the output parking lights. I switched brains and the one car still flashes, but the other car still don't. How does it hook up so the lights flash? is there something wrong with my one car that it doesn't work? It's a crimestopper alarm. Do i just have to run a wire to the parking lights or something? hope someone can help. thank you.
Shawn
Old Nov 18, 2001 | 10:34 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
It sounds like he didn't hook up the parking lights. Find the parking light wire (just use the wire at the switch.. i think its brown) Find the parking light output wire on the brain. Use a relay to run the parking lights using the output from the brain. Or, if you are sure that the brain has the output for the parking lights, go back to the installer and tell him to hook it up. He should have done that in the first place.
Old Nov 19, 2001 | 10:38 AM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
If you go to the brown wire at the light switch,you shouldn't need a relay.Sounds to me the installer just didn't hook up the parking lights for some reason.It is very simple: A wire from the parking light output of the "brain" goes to the low current parking light "turn-on" wire of the car(brown at the switch).
'91 RS, 375hp 350
New paint-solid black
ROH Snyper wheels-17x9 wrapped in 275/40/17
ASCD SS hood, High-rise Z-28 spoiler,shaved handles/antenna,
Hooker super comp 1 3/4" headers,dual 3" exhaust,two 1-chamber Flomasters,machined hi-perf GM heads,Holley double pumper 650 w/50cc pumps,Power Plus 360* high rise aluminum intake,Edelbrock Elite valve covers/14x4" open air cleaner,Mallory AFPR,Proform HI-perf HEI disributer with curve kit,Crane 292 cam,Eibach Sportline springs,KYB struts/shocks,completely rebuilt steering linkage,36/24mm sway bars,12.7 steering box,wonderbar,145 gauge cluster,Auto meter gauges,dual guage A-pillar pods,180* thermostat,dual push/pull cooling fans.
75-125 shot NOS system planned.
President-Austin 3rd Gen F-body c.c. - message board at
www.hpsmotorsports.net
See my car and others at www.ride4life.net
Old Nov 19, 2001 | 08:34 PM
camaro 22's Avatar
Great, I'll try it out. Thanks guys.
Old Nov 20, 2001 | 01:50 AM
AmorgetRS's Avatar
I had a question on this, if you turn on the parking lights the fog lights also turn on... is there a way around this?
Thanks,
Douglas
Old Nov 22, 2001 | 03:28 AM
Chris Luongo's Avatar
Amorget, yes, there is a way.
First go to www.the12volt.com, click on Relays. Take a little time there and learn about relays; they're cool.
Once you know how to wire up a relay, you can do just about anything you want. I can think of two solutions:
A. Wire the relay to interrupt the fog lights whenever the ignition is turned off. When the car is off, just your parking lights will flash. When the car is running, they'll work.
B. Wire the relay to interrupt the fog lights whenever the alarm flashes the lights. (You'll also need to use a diode to isolate the alarm's light-flash output from the car's parking light wire. Otherwise, turning the parking lights on manually would also interrupt the fog lights.)
Old Nov 22, 2001 | 03:57 AM
smokntires's Avatar
What kind of alarm is it? I might be able to tell you the color of the pk light output wire. Jered 1983SS
save your lungs smoke an import!
Old Nov 22, 2001 | 09:02 PM
camaro 22's Avatar
ok, i followed the harness from the brain for the alarm. It's a white wire with an inline fuse that is hooked up to a brown wire under the dash. Could there be something wrong with the car? This brain did work proper in my other car, so i know it's not the brain like the installer said. Could it be attached to the wrong brown wire? How can i figure this out? The alarm is a crimestopper 2 way pager fm alarm. Hope you guys can help. Thanks.
Old Nov 23, 2001 | 10:50 PM
RSpeed's Avatar
If you take a test light or meter and probe the brown wire,it should show power when you turn the parking lights on.If it does,then check for power on the white wire from the alarm that is connected to the brown wire,to ensure that the connection is good between the alarm output and the light wire.If everything checks out there,then keep your testlight on the white wire and activate your alarm with the remote and see if your test light flashes.If the output is working,then the testlight should flash when you arm/disarm the system.Also,did you check the fuse on the white wire?
Old Nov 24, 2001 | 10:59 PM
smokntires's Avatar
where did you tap the brown wire at? Also check the fuse on the white wire. Also do your parking lights and flashers work as normal? Jered 1983SS
Frozer!!!
Jan 19, 2024 04:55 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
