Driver side turn signs dont work properly...
Old Nov 24, 2001 | 02:10 PM
1982chevycamaroz28's Avatar
hi im tryin to get my turns signles to work properly. like when i put the hazards on all of them blink excupt for the back driver side. and when i put just the turn sigle on, on that side it just stays lit up and no blinky and still the back driverside turn signal wont light up. can any one give me any help i need to get this done for inspection. thanx
Old Nov 24, 2001 | 04:21 PM
silentneko's Avatar
you have a few bulbs out, atleast thats what was wrong with mine.
neko
'87 trans am
car in the making
Old Nov 24, 2001 | 09:10 PM
IROC&ROLL
Guest
Posts: n/a
Yup, you probably have a bulb or two out. They may have bad elements or just dirty connections. Get to the bulb(s) that aren't lighting and twist them back and forth to clean up the connections a little.
The reason they don't flash when the blinker is used, but do with the hazards is because the flasher works off of current. With a bulb or 2 out there is not enough current to operate the flasher, but there is with the other bulbs operating with the hazards.
Search the archives, I've covered this topic in more depth before.
Old Nov 26, 2001 | 02:56 PM
mtccl's Avatar
Don't forget to check the side marker bulbs too. Any bulb burned out in the set will cause your condition.
87 TA, 305 TPI, Custom CAI, K&N, ACCEL 8mm wires,ACCEL Super-coil, ACCEL Plugs, JET TPI Airfoil, Cherry Bomb Muffler, 160* thermostat
The Phoenix Project..click to see my project car
Trans Am stuff and GIRLS, GIRLS, GIRLS!!!!!
Terrell351
Jun 13, 2021 01:13 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
