Ignition switch wire colors
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I am trying to hook up an auto start but I can't find a good wiring diagram for the steering column. I have been to 3 different sites each show different colors for the wires. Does anyone know which wire is which? I think the problem is I am not finding the right diagram for my car. I have a 1989 Camaro IROC 350 with VATS.
1989 Iroc-Z 5.7 350, Blue, T-Tops
Lightly Moded:
Edelbrock Headers, Rebuilt B&M 700R-4 Tranny, Higher Stall Torque Converter, Airfoil, 3.4 w\posi, K&N's, Ported Plenum
-- Blue LED Bakelite Dash & Climate Control
"Just some 17 Year old spending every dollar I make on my car."
Lightly Moded:
(Snip) I have a 1989 Camaro IROC 350 with VATS.
I am probably not going to tell you what you want to hear, but I will say it anyway.
Don't do it!!
In order to install a remote starter, you will have to go ahead and disable VATS. VATS will save your car from any punk that tries to steal it. It has already saved mine once. I was thinking about doing the same thing, but one smashed steering column later I have a different mind set. Now that I have seen how easy it is to steal a GM product of this age, I would not recomend doing what you are planing.
Just trying to help...
Later,
Joe
Black '89 GTA, TPI 350...
Check Out Big Joe's Car Page's
Don't do it!!
Later,
Joe
Car: 1989 Iroc-Z
I bought an aftermarket VATS disabler that only disables the VATS when doing a auto start. If someone tries to steel my car the VATS will still be active.
Does anyone know the color codes of the wires?
Lightly Moded:
Lightly Moded:
Car: 91 Red Sled
I had VATS disabled with my remote starter. They tried to steal her, didn't happen because the Avital avistart6500 has a starter kill that is much more effective than VATS. VATS is the easiest thing to disable, I can bypass it in less than 5 minutes and that's just enough time for anyone to steal a car. Don't just use VATS, I have a list of a hundred ways to keep your car in the same place. Starter kill switchs, slow blown fuses on the ignition wire bypass, you name it, it's easy. Fuel pump switch, tranny position switch (car won't start if it doesn't know what gear it's in), ignition switch, starter relay switch, it's very easy. I repeat, do NOT trust only in VATS, it only takes 1 tool, 2 fingers, and a $.50 piece of electronics to bypass. I'm not aloud to post how and I won't, just don't think VATS is a magic shield. True, punks won't steel it. Auto theives will, and everybody knows that punks leave the car for dead, theives rip it apart at a chop shop and rid the plates and vin, you'll never see your car again. Good luck and just spend a few hours Sunday making a hidden switch for a starter kill!
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
http://www.geocities.com/vtcamaro/Wire-Diagrams.html
Tim
1992 Z28, 305 TPI 5 speed, 12.0 sec @ 114.8 mph
1984 Berlinetta 305 TPI Auto, 13.8 sec @ 99.7 mph
Tim
Car: 1989 Iroc-Z
Nice site!!! But I didn't find anything oh the steering column and what each wire is coming out of it. Can anyone tell me the color or each wire and what that wire does for the wires coming out of the steering column?
The ign switch is under the power distribution section:
http://www.geocities.com/vtcamaro/Pi.../pg105-106.jpg
Tim
Tim
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
If you still can't find it,e-mail me and I will give you all the info you need,including Vats.
'91 RS, 375hp 350
New paint-solid black
ROH Snyper wheels-17x9 wrapped in 275/40/17
ASCD SS hood, High-rise Z-28 spoiler,shaved handles/antenna,
Hooker super comp 1 3/4" headers,dual 3" exhaust,two 1-chamber Flomasters,machined hi-perf GM heads,Holley double pumper 650 w/50cc pumps,Power Plus 360* high rise aluminum intake,Edelbrock Elite valve covers/14x4" open air cleaner,Mallory AFPR,Proform HI-perf HEI disributer with curve kit,Crane 292 cam,Eibach Sportline springs,KYB struts/shocks,completely rebuilt steering linkage,36/24mm sway bars,12.7 steering box,wonderbar,145 gauge cluster,Auto meter gauges,dual guage A-pillar pods,180* thermostat,dual push/pull cooling fans.
75-125 shot NOS system planned.
President-Austin 3rd Gen F-body c.c. - message board at
www.hpsmotorsports.net
See my car and others at www.ride4life.net
'91 RS, 375hp 350
Car: 1989 Iroc-Z
Thank you RSpeed,
RSpeed was very kind and emailed me all the wiring colors. I am going to post them up so everyone can use them.
The following wires will be on the steering column
from the ign switch:
CONSTANT 12 VOLTS- Red
IGNITION 12 VOLTS- Pink
STARTER----------- Yellow
ACCESSORY--------- Brown
IGNITION #2------- Orange
Here are a few more wires for future reference:
TACH SIGNAL-------White wire at distributer
NUETRAL SAFETY----Orange/black
PARKING LIGHTS----Brown at the switch
DOME LIGHT/DOOR TRIGGER-- White wire at pin
switch.Also can be found at courtesy light under dash
if so equipped.
POWER LOCK--------Light Blue in driver kick panel
POWER UNLOCK------Black in driver kick panel.
BRAKE LIGHT SWITCH--Light blue or yellow at the switch
above pedal.
TRUNK PIN SWITCH--Orange/black wire at the trunk
light.
if so equipped.
above pedal.
light.
One thing I forgot to mention to 89 Iroc Z on the above post is that the TRUNK PIN SWITCH wire-orange/black,is for 85-92 models. 82-84 model years instead have a WHITE wire at the same location. And I also left out the TRUNK RELEASE wire,which can be found at the switch as a brown wire that sends a negative signal to the release relay.
[This message has been edited by RSpeed (edited November 27, 2001).]
Re: Ignition switch wire colors
Lightly Moded:
Lightly Moded:
LOL this poor old VAT system...
We (GM Engineering) used to purchase an analog 10k ohm potentiometer (variable resistor) with two small wire leads on a GM ignition key...
The key was cut as if it was a very worn-out old key...
Stuck the key in the ignition lock-cylinder, twisted the **** on the potentiometer back and forth slowly...
and in less than 2 minutes has the car running.
Theft-Testing like this is eventually what led up to the PASS-KEY 3 systems that actually works quite well.
..... All you have do is find a radio shack. Lol. Get an experimenters board and a trim pot. Find out your residence of your key set the trim pot to that resistance. Locate the key reader wires under the steering column. It'll be a special two wire plug. Extend those wires so you can put your experimenters board in your center console. Then hook up your two wires between the two pins of your trim pots swipers where you Read your resistance. Now you can change your lock cylinder to one without the little thingy in the key. So now you can get keys made anywhere. Now you have permanent bypass for the system. I have this knowledge from converting my 89 Camaro's system. Here's the Kool thing, whenever you park your car grab your experimenters board from console and put in your pocket and your car is now disable. It'll turn over but never start. Also after you set to proper resistance super glue the trim pot screw so it doesn't move. I've included the resistance key blank chart above and use the design resistance column. You see I had to use the chart and my multimeter and test every resistance until my car started. With the trim pot method you can have the exact resistance because using resisters can be tricky and **** you off. You never need to worry about losing the resister in your key because that's what happened to me. Hope this guide helps you. Please don't cut any of ignition wires and throw that vats bypass module away
Since your new here I'm gonna say two things ; First , welcome to TGO , the finest third gen F body site online !
And second , please check the date of the threads you respond to , you just bumped a 19 year old thread and I'm pretty sure by now the guy has his remote starter installed
Car: 87 Camaro Multi-port Fl
Engine: Ls 5.3
Transmission: 4L 60 E
Thank you RSpeed,
if so equipped.
above pedal.
light.
if so equipped.
above pedal.
light.
Engine: Ls 5.3
Thank you RSpeed,
if so equipped.
above pedal.
light.
if so equipped.
above pedal.
light.
did a LS swap on my 87 Camaro 2.8 Multi-port Fl Third GEN And somebody bypass the starter wire to the ignition to turn over the starter and I can’t figure out which wire is for that anybody have any Answers or I can help me with this
I did a LS swap on my 87 Camaro 2.8 Multi-port Fl Third GEN And somebody bypass the starter wire to the ignition to turn over the starter and I can’t figure out which wire is for that anybody have any Answers or I can help me with this
Engine: Ls 5.3
Thank you RSpeed,
if so equipped.
above pedal.
light.
if so equipped.
above pedal.
light.
Ghettobird52
Jul 5, 2024 11:18 PM
