Whats a cause of no gauge lights when the lights are turned on?
Old Nov 24, 2001 | 08:55 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
My post says it all.I have an 85 SC and the dang things gauge cluster wont light up when I turn the lights on.I have check and changed every fuse for the fuse block.I recently put a gauge cluster form a IROC into my car,It previously had stars war gauges.When I got the IROCs the gauge lights worked when I turned the lights on.Did anybody have the same problems,and were able to fix it?
Old Nov 27, 2001 | 02:18 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The 5 ampere INST fuse is powered from the rheostat (dimmer control) in the head light switch. If there is no power to the INST fuse with the light switch on & the dimmer in the full bright position, then the rheostat in the light switch may be defective. Here are the schematics for your '85:
http://www.geocities.com/vtcamaro/Wire-Diagrams.html
Tim
1992 Z28, 305 TPI 5 speed, 12.0 sec @ 114.8 mph
1984 Berlinetta 305 TPI Auto, 13.8 sec @ 99.7 mph
Old Dec 1, 2001 | 11:54 PM
langss's Avatar
Car: Assorted
Engine: Various
Transmission: Manual and Automatic
Could be the remote dimmer has failed. Its located behind the data link under the dash. See the post about the Digital Dash light.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Fronzizzle
Aug 17, 2015 02:52 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
