NO DATA AT ALDL HELP
Old Dec 6, 2001 | 11:02 PM
my89formula350's Avatar
ANY BODY HAVE AN IDEA WHY WHEN I TRY A TECH 2000 SCANNER WITH THE TPI ENHANCER I GET NO DATA GIVEN HAVE TRIED IT WITH ONE OTHER SCANNER SAME THING LET IT RUN FOR AN HOUR NO DATA BUT YET YOU CAN JUMP ALDL FOR CODES WORK FINE ANY HELP WOULD BE GREAT THANX
PAUL REED
Old Dec 7, 2001 | 12:31 AM
JPrevost's Avatar
Car: 91 Red Sled
Never heard of that scanner. You sure it isn't just ment to display error codes and that's it? How much did you pay for it.
Old Dec 7, 2001 | 06:21 AM
THANX FOR REPLY IT IS FOR DATA STREAM IT IS A GMTECH UNIT USED BY GM COST 1200.00 HAVE TRIED A XRAY ALSO STILL NO DATA ANY IDEAS .......
Old Dec 9, 2001 | 12:02 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Please dont type in all capital letters.
I just worked on a car today with the same symptoms as yours. You can use a paperclip and get codes, but hooking up a scantool would get nothing. It turned out to be the ECM itself. I swapped it with another spare, and the problem was fixed.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
318 RWHP, 419 RWTQ
13.23 @ 107.62 MPH (2.13 60')
Southern California
Member: SoCal F-Bodies
-=ICON Motorsports=-
Falcon50
Aug 22, 2020 03:26 PM
xodus2002
Jul 17, 2020 09:08 AM
bjpotter
Oct 4, 2015 07:48 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
greenyone
Sep 8, 2015 08:41 PM
