Air Fuel Ratio Gauge
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
That should do it. The gauge will also require a ground (ECM ground), +12 volts (gauges fuse), and dash light input.
Axle/Gears: 3.45, 3.27, 3.27
Yep, just splice into the O2 sensor wire as close to the sensor as possible. Careful though. The wire may be brittle due to heat damage. It is a good idea to wrap it with aluminum tape or insulation. You'll have a +12v source and ground required as well.
Lon
Lon
Actually it's not necessary to attach the gauge input wire near the sensor - connection @ the ECM is OK, since it's not a balanced signal. It is a good idea, however, to connect the gauge sense ground to the O2 sensor ground @ the ECM for minimum noise, although the NB O2 gauges typically have a relatively slow response time, so noise will be averaged out.
Ghettobird52
Jul 5, 2024 11:18 PM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
