bypassing VSS
bypassing VSS
What kind of signal does the VSS use? Pulse? I was just thinking about how to bypass the speed limiter without loosing the speedo. If the VSS sensor sends out a pulse it could be possible to use a chip to devide the pulse by two to gat a halved reading making it possible to get a reading even at higher speeds and still get a reading of it. Therefor if you have a 115 speedo (like me
) you could get reading upto 230 mph (368 km/h to us europeans)
Idias?
Idias? Supreme Member
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
That would work - I believe that the VSS signal to the ECM from the VSS buffer in cable driven speedo systems, is a 0 - 12 volt 4000 pulse per mile signal. With an electronic VSS setup (non cable driven speedo), where the VSS buffer is built into the ECM, the magnetic pickup signal generated @ the VSS would have to be intercepted & regenerated to do the divide function before the ECM saw the signal. It would probably be easier to change the PROM code to defeat the speed limiter function.
Tim
1992 Z28, 305 TPI 5 speed, 12.0 sec @ 114.8 mph
1984 Berlinetta 305 TPI Auto, 13.8 sec @ 99.7 mph
Tim
TMZIrocZ350
Oct 7, 2015 12:09 PM
