I have MAJOR problems
Old Oct 22, 2002 | 09:12 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Ok I have and HEI distributor and a holley carb, so my car is not computer controlled. The fan has its own littile wiring by me as does the fuel pump. I cut ALL the wires coming out of the passenger side fender and ALL the wires coming out of the box that I attached a picture of. The alternator is putting out 15 volts and is in good condition. To the best of my knowledge the battery is good, but you never know. When I charge my bettery and leave the car alone it will keep its 12 volts. When I drive around though the alternator is not charging the battery. With the healights on and everything the battery will go dead pretty quick - it has 3 times now. What did I cut that I should not have. The alternator wires are all in tact. The battery cables are good. What is wrong, what do I need to do? Can I just run the some wire directly somewhere, it doesn't have to be exaclty how it came stock - I will fix that later.
THANKS
Old Oct 23, 2002 | 01:13 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
You do have a computer even though your car came stock with a carb. The computer controls Spark advance (The HEI distributor) and EGR. That thing you have an arrow to is your map sensor.
Old Oct 23, 2002 | 07:35 AM
I have a 1992, it was originally a LO3. Which wires were a no no to cut?
Thanks for the reply.
Brady
Old Oct 23, 2002 | 02:00 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
This may help you if you just want to rewire the alt.
Old Oct 23, 2002 | 08:32 PM
thanks guys but unfortuately the car is going to go to the shop tommorrow i can do many things with a car but fixing wiring is not a strong point
once again thanks though
Old Oct 24, 2002 | 11:42 AM
Nate1's Avatar
Car: 88 IROC-Z, 71 SS 454 Chevelle
Engine: 305 TPI, 454
Transmission: 5spd, th400
Brody,
Just run a 10 gauge wire from the back of the alt to the pos of the battery. Also you can run the red wire from the plug (that plugs into the alt) to the post on the back of the alt.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
andy74
Sep 3, 2015 08:41 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
mrdevontay
Sep 2, 2015 08:04 PM
greenyone
Sep 2, 2015 03:39 PM
