frustrating
Old Nov 5, 2002 | 09:35 PM
bandit45's Avatar
frustrating
Alright I finally got my car running so I threw on the valve cover and they were the usual pita to get on. I had my dad help me and he pulled on the wiring harness a bit trying to get the cover under it. My tps is just connected by wires twisted together but it ran with it before and they are still connected. Now after puting on the covers I tried to start the car and its turns but the injectors arnt giving any gas. So whats my problem?? I'm so frustrated i would really apreciate it if someone could help.
Old Nov 6, 2002 | 08:45 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
it sounds like you already know your problem, you just dont want to hear it. you should never try to cut corners and not put some kind of conector on there to relieve wire tension.
Old Nov 7, 2002 | 01:55 PM
bandit45's Avatar
Not I dont really think thats the problem, the injectors would still shoot gas even if the tps was messed up.
Old Nov 8, 2002 | 08:15 PM
Andy Bush's Avatar
If you are sure the tps wires are OK, you may find the connections to the distributer might have been pulled off. The wiring in the engine bay looks like it was designed to be pulled loose if you even just look at it.
gta892000
Aug 11, 2019 11:16 AM
1992CamaroGirl
Dec 25, 2017 08:45 PM
RedLeader289
Sep 23, 2015 06:50 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
