87 T/A speedo into 89 IROC?
Old Nov 16, 2002 | 02:42 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
Is the speedo from an 87 T/A the same as the one in a 89 IROC?, have a chance to get one free and need to know
Old Nov 16, 2002 | 08:51 PM
86TransAMsbc305's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
Similar but pretty sure not the same
Old Nov 16, 2002 | 09:03 PM
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
the connections should be close enough to work, but it will look off as the writing is different and the lighting will be orange due to the color they are painted. might be a different size too. the holes look about the same though. and you will have to make sure it goes up to the same speed as your current speedo, otherwise you will have to get the same speedo gear to make it accurate.
Eric2ndGen
Nov 5, 2015 01:51 PM
IMissMy86TA
Aug 31, 2015 08:40 PM
stickychinsac
Aug 31, 2015 06:06 AM
mustangman65_79
Aug 11, 2015 03:17 PM
