bunch of stuff not working
Old Nov 23, 2002 | 01:59 PM
Iroc n roll's Avatar
Ok, I just rebuilt my engine, and now half my gauges don't work. Specifically, my tach, volt meter, oil meter, and temp meter. My tach has always had problems so it might no be related to this. In addition to this my SES light won't come on when I turn the key, or my E-brake light (when it's engaged of course). What's missing? I'm pretty sure my fuel gauge still works, I haven't had a chance to test the speedometer. What's going on? I don't think it's the fuse either since I have 2 aftermarket gauges using the same fuse which are working fine.
Old Nov 25, 2002 | 01:46 AM
Can anyone give me a place to start?
Old Nov 26, 2002 | 11:56 AM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
well the first thing to check is if everything got plugged back in and hooked up correctly....temp guage to the sender in the drivers side of the motor, tach to the coil, oil pressure to the sender below the distributor, I dont remember where the volt guage draws from, are all the engine grounds hooked up? are all the connectors to the ECM connected? check your fuses anyway, cant hurt.
Old Nov 26, 2002 | 05:43 PM
I've already checked the connections of the sensors, it's the locatoin of the grounds that I'm worried about. I'm not sure where they all are. I've been checking through the harness for little loops hanging out. I have a feeling I'm just missing one major one though. I'll keep checking.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
NBrehm
Aug 25, 2015 11:49 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
