How to install Fog Lights?
Old Dec 8, 2002 | 10:06 PM
restoIROC's Avatar
Car: 2000 Monte Carlo SS
Engine: 3.8 V-6
I bought my 86 IROC with no foglights so, I bought the brackets and mounting bolts and am going to use plastic KC fog lights to replace the metal stock lights. Now where I run into problems is were to mount the brackets. There should be predrilled holes, right? The brackets are shaped in a L with one hole on one side and two on the other, how does that works?
Thanks-
Old Dec 9, 2002 | 11:29 AM
1991rsblue's Avatar
there are predrilled holes for the factory attachments and brackets. what i did was when i put mine in, which didn't have them before, i just drilled my own and attached them with better bolts and if you want to make your life easier if you need to take them out tap the holes.
Old Dec 10, 2002 | 08:12 PM
restoIROC's Avatar
Engine: 3.8 V-6
Nice...
Hey thanks,
I figured that I would probably have to drill new holes, your picture helps, thanks-
Ben
Old Dec 11, 2002 | 07:50 AM
1991rsblue's Avatar
just make sur they are even, or they look really funny. and when you hook it up use a relay don't hook it up directly to the switch you are going to use and fuse it also.
Old Dec 12, 2002 | 02:21 PM
MdFormula350's Avatar
https://www.thirdgen.org/techbb2/sho...hreadid=148847
jaridjohn
Jul 8, 2024 03:49 PM
TheExaminer
Aug 26, 2015 04:59 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
