MSD-6A Wiring Harness
Old Dec 11, 2002 | 10:31 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Hello,
I just bought an MSD-6A Ignition Box for my 1991 Z28. Somebody said that wiring harnesses are available for these so you don't have to cut any wires or anything. Does anyone know where I can get one of the harnesses??? I don't want to cut anything or mess any electrical stuff up. Any Info would be appreciated. Thanks!
Old Dec 12, 2002 | 09:42 AM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
The one i got it part# 8861. Not too sure if it works yet b/c i have not installed them. I have the 6AL, so i do not know if its going to be different. I got mine from Summit. It says "GM HEI MODULE BYPASS CABLE". good luck
Old Dec 13, 2002 | 09:42 PM
3gc's Avatar
3gc
Car: Z28
I'm going to be using the 8876 harness. I haven't installed it yet. but hooked everything up to make sure I know what I'm doing when I install it. This is what summit says about the harness:
MSD offers these harnesses to simplify the installation of a MSD 6 series box on late model vehicles. The harnesses plug in between the ignition coil and the factory coil connector. Four wires with corresponding colors and matching connectors then connect directly to the MSD 6 wires. These harnesses reduce the installation time, eliminate cut wires and allow you to quickly convert back to the factory ignition if ever desired.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
