left turn signal doesn't work.
Old Dec 13, 2002 | 10:31 AM
hurricanerugger's Avatar
I just picked up my new(to me) Trans Am, and I found out on the way home that the left turn signal doesn't blink, it just turns on and stays on. I checked to see if any of the lights were out, but they weren't. What could this be? The right one works just fine. And the gear indicator on my car doesn't work either. It's an automatic, and I can never tell if I'm in D or OD because it will slip by so easily. Thanks.
Old Dec 13, 2002 | 10:12 PM
3gc's Avatar
3gc
Car: Z28
The flasher is probably broken. It's about a $2 item. Worth a try. The flasher is located in the Convenience center. It's above the drivers foot. I heard it's hard to get to though.
I'd just replace the shifter plate to fix the gear indicator problem.
Old Dec 14, 2002 | 11:09 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If one side flashes and the other doesn't, it's likely there is a bulb out somewhere (could be something as silly as the side marker). Both left and right signals use the same flasher relay.
The best way to check is by turning on the hazzards and walking around the car, the hazzards will flash regardless of burnt out bulbs.
Old Dec 14, 2002 | 03:17 PM
MdFormula350's Avatar
check the buld first, usually when one goes out that side just freezes.
Fronzizzle
Mar 18, 2019 08:29 PM
Derick15
Sep 17, 2016 05:28 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
