Short wire somewhere
Old Dec 22, 2002 | 10:31 AM
Wootah's Avatar
Car: 88 Iroc-Z
Engine: 355ci
Transmission: WC-T5
Well, my dome light, radio memory, horn, cig lighter, rear hatch switch, and power doorlocks dont work. Where should I look for a short, any ideas? Also when i was messin with my engine yesterday i noticed that the wire that tires into the back of the block was not hooked to the block. I guess its the ngine ground or block ground or something. Could this cause it? If not, whats that wire for? Its flat and about half an inch or less wide. Thanks!
Old Dec 22, 2002 | 10:48 AM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
I would start by looking inside the door jams, where the wire for the locks and sutff go from the inside of the car out to the doors. THey usually get cracked or broken in side there causing locks and power windows to not work and so on. THis is most likely where your problem is. HTH
PS: the flat mesh like wire is a gound strap, but there are alot of other grounds on the car so I don't think that is causing your problem, but I would hook it back up.
Old Dec 30, 2002 | 12:28 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Sounds like you blow the accessories fuse
Old Dec 30, 2002 | 01:25 AM
MdFormula350's Avatar
have you changed the acess. fuse yet, see if its blown..
also hook that one wire up, you were talking about, no sense in just letting it dangle.
Old Dec 30, 2002 | 07:54 AM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Hmmm...no reply yet. Wonder if he got it fixed????
Old Dec 30, 2002 | 11:57 AM
88TAJeff's Avatar
Car: 88 T/A
Check your cig. lighter. It may be all crusted and corroded, causing a short. Un-plug it, put a new fuse in and see if it blows.
Street Lethal
Apr 30, 2019 12:14 PM
Infested
May 22, 2018 11:56 PM
Reddeath210
Oct 6, 2015 08:20 AM
Bryan F
Aug 18, 2015 02:28 PM
