how do i hook my fans up 2 come on with ignition?
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
well title basically says it all.. i have no computer.. have the wires from the fans splicted off where charcole container would be.. have 2 wires from pervious owner spliced off which i was told are to the ignition when its in the on position... how do i go about hooking this up.. would i need a relay or somethin?
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
This might help you..
https://www.thirdgen.org/techbb2/sho...11#post1061811
Car: "02 z-28
Engine: LS-1
Two fans two relays is a must. ignition controlled operation of two fans is not necessary and will kill the alt and fans in short order. get a cooler fan switch and install it where the original one was. pass side bet cyls 6&8. tie both relay coils(one end of coil) together and then hook that up to the fan switch. the fan sw will easily handle two relay coils since they draw very little current. hook the rest of the connections up standard wiring. all you will do eliminate is ECM control of the primary fan(which you don't have) and let the fan sw take over for the control of BOTH relays. NAPA has two different fan switches for TG's and they run $19. One comes on at 220 and the other at 238. You can get cooler ones from JET. This will give you the cooling and give the electrical system a rest.
hmmm thanx for the replys.. i sorta figured it out already... but as far as the second reply.. the problem with that is im not really tryin to run over 180 degrees... i know its kinda wishful thinking in a 3rd gen but thats what the engine makes the most hp and torque at.. hotter it declines... need a better radiator.. but i need money 2...
with em on all the time i stay around 190-200 when its cold out with a 160 in.. in the summer if i drive enough it will over heat.
Car: "02 z-28
Engine: LS-1
yeah i think its a mixture of heat issues really.. all the forged components give all a little extra heat.. crank, rods, pistons, etc... plus my ****ty headers arnt really doin it any favors... they WERE ceramic coated but from it sitting for a while they started to rust a tad and a lot of it is flaking off...
FormulasOnly
Sep 10, 2015 09:07 PM
