Voltmeter
Old Jan 5, 2003 | 06:59 PM
usa1racing's Avatar
Voltmeter
Where is the best location to hook up the positive wire on an aftermarket voltmeter to read the voltage drop with all the normal accessories on, e.g. fans, headlights, gauges, etc.?
Old Jan 5, 2003 | 07:44 PM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
fuse box?
Old Jan 6, 2003 | 04:52 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
The factory uses the blower motor 12 feed line to sense voltage drop for the alternator control. That line will probably provide the most drop and would be a good point to look at the worst case. You can tap into it at the fuse block. Tap into the side where the voltage disappears with the fuse pulled, that way your wiring will be protected by the fuse in the event of a pinch or short.
Old Jan 7, 2003 | 11:08 AM
MdFormula350's Avatar
i used a fuse tap on my friends car, on his fuse box.. i used the a fuse that only had power when turned on.
Old Jan 7, 2003 | 02:27 PM
ebby53's Avatar
Might find this interesting..............
http://www.madelectrical.com/electr...eadlights.shtml
NTChrist
Mar 10, 2002 12:40 PM
Gary
Sep 18, 2001 03:51 PM
BrianB
Sep 7, 2001 04:18 PM
GTA88
Jun 25, 2001 04:47 PM
