trouble identifying ground wire
Old Jan 8, 2003 | 09:35 AM
90form305tpi's Avatar
Car: 1990 Firebird Formula 305
Engine: 305tpi w/145,000 on the clock
This is my first post on TGO. I have a 90 formula w/ 305 tpi. I just bought it four months ago and have been having fun with it since. When I changed the cap and rotor on the distributor I noticed a braided copper ground about 3/16 to 1/4 in. wide. It comes off the fire wall and is cut(almost looks melted) in half. I cannot see the other half of the wire nor where it goes. I need to know what this is a ground for, and if it needs to be replaced with "braided copper wire", or if I could just use some very heavy gauge wire. Any help of course would be greatly appreciated.
I would also like to say how grateful I am that such a website exsists. The advice I have seen on the boards and in the archives has helped me many times. So thank you to the moderators and anyone else who should be recognized.:hail: :hail: TGO
Old Jan 8, 2003 | 10:17 AM
MdFormula350's Avatar
sounds like maybe an engine ground..
Old Jan 8, 2003 | 06:58 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
it should go to a bolt on the back of the cylinder head, you can replace it with standard wire
Old Jan 9, 2003 | 09:13 AM
Jza's Avatar
Jza
Just make sure it's heavy gauge multi-strand wire.
Otherwise, just go into a parts store and ask for a "ground strap". That thing going bad can cause all kinds of wacky problems, including slow cranking and hard starts.
Old Jan 9, 2003 | 10:33 AM
Thanks a lot. I've had trouble diagnosing a hard start problem and that could be it. I will go today to get a ground strap and I'll post the results. Thanks again.
Old Jan 10, 2003 | 09:23 AM
I fixed the ground last night. It not only cured my hard start problem, it also helped (a lot) with a rough idle when hot problem I was having. It's a twenty minute drive to work and this morning there was a twenty min. traffic jam , and it was warm this morning(I live in FL ). The car got to peak temps and still did not idle rough. I was &*%$# thrilled.
Old Jan 10, 2003 | 10:14 AM
Jza's Avatar
Jza
Old Jan 11, 2003 | 12:06 PM
yeah thats great!!
Glowsock
Jul 24, 2025 03:15 PM
eightsixseven
Dec 16, 2024 01:50 PM
backtothe80s
Sep 5, 2015 12:39 AM
Jae992
Aug 27, 2015 09:07 AM
djmarch
Aug 19, 2015 12:07 PM
