Sensor on passenger cylinder head?
Old Jan 8, 2003 | 09:48 PM
GTA600's Avatar
It looks like there is a sensor slightly above the knock sensor...located on the passenger side cylinder head between cylinders 4 and 6....what is this sensor and does the wire that connects to it bundle with the knock sensor wire? do the connectors look the same?...its a single black wire with a pin looking connector that slides into a small tube like female end....anyone know...87 LB9
Old Jan 9, 2003 | 06:23 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
electric fan switch, the connector looks the same as the knock sensor and the wire should be dark green or black
1992 Trans Am
May 10, 2023 07:19 PM
NinjaNife
Aug 23, 2015 11:49 AM
Randomtask2
Aug 13, 2015 01:57 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
