1990 Guage cluster wiring harness issues
Old Jan 15, 2003 | 11:27 AM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
Im currently well into my 98 dash swap into my 90 iroc and im having truoble with some of the wirign harness formt he old cluster, namely the speedo and fuel guage wires.
Doesn anyone happen to knwo what color or what pin those 2 wires are? Your help is GREATLY GREATLY GREATLY GREATLY appreciated.
Old Jan 15, 2003 | 06:05 PM
TtopIroc's Avatar
nope damnit i already told u
Old Jan 15, 2003 | 06:10 PM
Aron213's Avatar
Car: 88 Iroc
if you cut the wire and splice in a new one you can make it any color you want.
Its that easy Nick!
Old Jan 15, 2003 | 06:11 PM
TtopIroc's Avatar
yea just put a pink one in and your set...
Old Jan 15, 2003 | 06:34 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
you do know you need a dakota digital converter to make the speedo(and tach if it is from a v6)work, right?
Old Jan 15, 2003 | 06:58 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
Shouldnt since the 4th gen speedo uses a 4kppm just liek the 90-92 thirdgens.
And yes i have one and if soemody wnats it, 87 bucks shipped, brand new.
Old Jan 16, 2003 | 06:42 PM
BOTTLEDZ28's Avatar
Transmission: A4
Aron213,TtopIroc, if you cant give any tech advice then dont bother posting at all. both of you guys have less then 20 post between the two of you and I bet they where all like these.... advice
Old Jan 16, 2003 | 10:17 PM
Aron213's Avatar
Car: 88 Iroc
ok Nick is a friend of ours, so we were playing around, and who are you to tell us what we can do...yeah thats what I thought!
Oh and as far as only 20 post, look around on other boards, besides just thirdgen.org you might just realize that the three of us might know a thing or two.
Old Jan 16, 2003 | 10:54 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
Old Jan 16, 2003 | 10:56 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
Originally posted by CustomX
Shoulda been ROFLMAO at that one.
Old Jan 16, 2003 | 10:57 PM
Aron213's Avatar
Car: 88 Iroc
oops i meant "customX" not Nick! Oh sh*t I bet hes pissed now I have 12 post!
Old Jan 17, 2003 | 08:54 PM
TtopIroc's Avatar
Im laughing so hard my ********* hurt......
Dude get a grip dont pretend your a thread G/O/D......
Old Jan 17, 2003 | 08:55 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
fyi, its the thick dark grey one on the left harness thats the speedo since nobody esle seems to know actual wiring.......
Old Jan 17, 2003 | 08:57 PM
TtopIroc's Avatar
ha this makes 9 and i suppose this is good tech advice
Old Jan 17, 2003 | 09:41 PM
BOTTLEDZ28's Avatar
Transmission: A4
Custom X, I am having issues with my speedometer. I orginally had isues with the cluster lights and had the wrong grey wire hooked up. So your saying if I take the thick grey wire out of the left harness on the car and hook it up to the grn/wht wire on the 4th gen connector that my speedo will work?
Have you made any progress with the fuel gauge? Is there anyway to determine for sure if its computer controlled
Old Jan 17, 2003 | 10:24 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
Yes, mine was a slightly darker grey then the rest, dotn remebr which pin because i cut the connecotr out in my frustration lol.
The lights, im having trouble with as well........
Fuel guage...i have no clue, i hooked up the purple wire liek u said.no go. I have a bad feelign its comp controleld, but at least i got the digital odo working lol.
Old Jan 17, 2003 | 10:31 PM
BOTTLEDZ28's Avatar
Transmission: A4
When I first turned on my lights to see if the cluster lights lit up, all the warning lights came on instead . I knew it had to be a wire so I just probed all the wires with a test light to see which one got 12v when the headlight switch was pulled out. I knew the 4th gen harness' cluster lights wire was grey so I just spiced them two together, basically I had the grey wire on the left connector spliced into the 4th gen harness. I do have wires that are not connected from the 3rd gen harness. One of them is the grey wire on the left harness now. all my other gauges work perfect and so does the air bag, brake, SES, and seatbelt light.
Old Jan 17, 2003 | 10:47 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
ya my air bag works, ses, brake, turns, security is inop now, as well as tcs (didnt want to see lights so groundy/cut).
Do you remeber if it was the ip illumination or odo illumination you connected the third gen wire to? and it was left side for illumination.......?
Old Jan 17, 2003 | 11:00 PM
BOTTLEDZ28's Avatar
Transmission: A4
you got me thinking now. If the cluster lights are not lighting up then the grey wires are crossed somewhere. I cannot remember right now what I ended up doing. I wll check it tomorrow. The left connector had 2 grey wires and the right had one. My 4th gen connector had 2 grey wires. I had 1 of them spliced into the 2 grey ones on the left cluster. and the other spliced into the grey on the right one. After that didnt work I probed all 3 grey wires to see what one was cluster lights and then just hooked that one to my 4th gen cluster grey wire. Yes i Know I said there was 2 on the 4th gen one but I cant remember what I did with the other one. Maybe it wasnt used. Sorry I cant be of more help right now. I know what your going through it sucks and its frustrating. How many grey wires are on your 4th gen connector?
Old Jan 17, 2003 | 11:20 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
Pin a3: security
pin b2: Ip illumination lamps feed
Frozer!!!
Jan 19, 2024 04:55 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Reddeath210
Oct 6, 2015 08:20 AM
355sbcTPI
Aug 19, 2015 04:38 PM
