145 mph tach swap quick question
Old Jan 23, 2003 | 03:13 PM
chefdan1's Avatar
allright i am getting a 145 mph speedometer and i am wandering the exact process to switch it out. my car is an 85 and the speedometer only reads to 85 well anyways here is a picture of it thanks you guys.
Old Jan 23, 2003 | 05:13 PM
Morley's Avatar
Remove old speedo...install new, reinstall cluster and hook up cable. Take it for a spin and make sure the speedo is working.
Old Jan 23, 2003 | 06:11 PM
chefdan1's Avatar
so i should not use the entire device just the speedometer?? i was installing the led's last night and i saw behind the speedometer and it kinda scared me im learning a lot about my car but i just don't want to screw anything up?? yall understand me right?
thanks for the help
Old Jan 23, 2003 | 08:22 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The entire assembly (cluster) swaps. You don't have to replace the gauges individually.
One note to make though, if you have idiot lights (no gauges except speed & gas) in your original cluster, you will need an oil press. sender and temp. sender to make the respective gauges operate properly.
Old Jan 23, 2003 | 08:55 PM
Morley's Avatar
Well if you are getting the entire instrument cluster, then yes, use it. You did say you were getting a 145 speedo though, I took that to mean just the speedo.
Old Jan 23, 2003 | 09:04 PM
chefdan1's Avatar
what you see at the top is what i am getting. so i guess what i need to know is how to take the entire device out. i know how to take off all the coverings but it is when it gets to actually yanking everything out that scares me i know i am making to big of a deal out of all of this but i don't want to screw up this 145 mph cluster!
thanks everyone i guess what i need to know is after i get past the small bolts what do i need to do
thanks again!
Old Jan 24, 2003 | 08:19 AM
Morley's Avatar
thanks again!
You need to get up behind the cluster to remove the speedo cable. Then its just a matter of removing 2 nuts on the front after the lens is removed, the nuts are down at the bottom sitting in two of those pockets.
Old Jan 24, 2003 | 11:12 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Take this opportunity to replace the stock 194 bulbs with xenon high-intensity bulbs from McEwen (the difference is remarkable). For another idea, check the thread below. You might also consider white-faced gauges, if that appeals to you.
https://www.thirdgen.org/techbb2/sho...hreadid=107995
JamesC
Old Feb 9, 2003 | 06:57 PM
zed's Avatar
zed
Car: 1991 Z28, 1984 Z28, 1990 Toyota 4x4
Engine: L98, L69, 22RE
Transmission: 700R4, 700R4, 5Speed Manual
Axle/Gears: 3.73, 3.23 Posi, 4.10
lens for speedo and gauges
does anyone know where i can get a new lens for the gauge package?
i bought one off ebay as well, works great, but the lens is really scratched up.
thanx
zed
Old Feb 9, 2003 | 08:13 PM
JamesC's Avatar
The last I knew, the lense was still available from GM, which is where I purchased mine.
JamesC
Jorlain
Aug 24, 2022 05:11 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
