PLEASE HELP ASAP!! Alternator, starter & dist. wiring
Old Jan 31, 2003 | 05:51 PM
89ROC's Avatar
Can anyone tell me which wires go to the alternator, starter, and distributor. Here's a pic of the harness at the firewall.
Any info will help!! Thanks!
BTW, I'm using a serpentine belt setup. The harness is in my 84TA.
Attached Thumbnails PLEASE HELP ASAP!! Alternator, starter & dist. wiring-mvc-016f.jpg
Old Feb 1, 2003 | 08:30 AM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
ok, not 100% sure, but violet(purple) goes to the small terminal(closest to block I think)on the starter, pink is coil(dist.), now it gets tricky without a wiring diagram, one of the reds goes to the alt, one goes tobatt+(large terminal at starter) them a brown should go to the alt. and anougher red(maybe pink or pink/blk), you can find wiring diagrams (for an 85, should be the same) here http://www.geocities.com/vtcamaro/Wire-Diagrams.html
Old Feb 1, 2003 | 02:53 PM
89ROC's Avatar
thanks Dave! I think I have everything figured out except for the distributor.
I'm having trouble locating the power wire and the tach wire....anyone??
Old Feb 1, 2003 | 11:56 PM
radiateu2's Avatar
Tach wire should be yellow and the distributor wire should be pink or red
Old Feb 3, 2003 | 09:43 AM
89ROC's Avatar
Thanks everyone! I got it all figured out, and the car is finally running!
Caspar
Jun 19, 2016 11:19 PM
dutch930
Sep 11, 2015 06:58 AM
Accerrito22
Aug 23, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
