smoke commin out of the stearing column
Old Feb 1, 2003 | 08:58 AM
brig's Avatar
My wipers (92 firebird) will only work on slowwwwww then when i turn them on smoke comes out of the column. Is this the wiper motor?
Old Feb 1, 2003 | 05:53 PM
SilverSub122's Avatar
you may have a short in the wiper wiring in your column. although im not sure i dont think the wiper motor is in the column.
Old Feb 1, 2003 | 05:58 PM
90Formula-X-F's Avatar
Car: 90 Formula
Engine: 355 C.I.
Transmission: 5 Speed
Silver is probley right. The wiring comes up through the column and routes around to the t/s switch lever. Be looking in the area of the T/S lever for the fault or maybe the switch it self came apart. The lever on the T/S switch isn't the switch but the switch is at the base of that
Old Feb 1, 2003 | 06:02 PM
patrickm00's Avatar
it could be a wiper motor, or the resistors that control its speed. when the a/c clutch on my friend's camaro locked up, we got a plume of smoke out the top of the column. and it might be simpler to pull that motor than all the stuff in the steering wheel on a 92. if you do the wheel though, make sure you disable the airbag safety under the dash. it has its own power source separate from the battery.
Old Feb 7, 2003 | 09:55 AM
brig's Avatar
Thanks so much. I think I just realized what I did. I washed the car on one of the coldest nites and froze the wipers so I guess when I was trying to use them while they were frozen it must have burnted out the motor.
FormulasOnly
Jul 23, 2018 08:47 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
KCG
Sep 23, 2015 09:05 AM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Accerrito22
Sep 5, 2015 09:34 PM
