Back Up Lights
Old Feb 7, 2003 | 11:53 AM
cris's Avatar
Back Up Lights
ok guys i have a 92 RS with the T5, when i shift into reverse my backup lights stay off, i replaced the bulbs and the fuse that said Turn b/u. is there a switch on the tranny that i need to check or somthing?
Old Feb 7, 2003 | 10:58 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
open your shifter plate up, there's a switch on the shifter - if it ain't in the right position, they won't work. maybe it's just loose, that's what was wrong with mine...
KAM
Old Feb 7, 2003 | 11:29 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The reverse switch for a T5 is on the drivers side of the trans case with a blue & a green wire on it. I believe you're thinking of an auto shifter thunder.
Old Feb 7, 2003 | 11:48 PM
cris's Avatar
is it like a big black box with an arrow pointing to the nose of the car? a couple inches behind the shifter or is it under the rubber shift boot, i have the consol all out and theres wires for the E brake, 2 going to the black box, and then 2 for my hatch switch
Old Feb 8, 2003 | 12:13 AM
deadbird's Avatar
Engine: TPI 305/ v6
cris.. a T5 tranny (standard shift) has no wiring on the shifter. Taking apart your console will net you no progress to your problem unless you have an automatic.
reverse switch is located here...
Old Feb 8, 2003 | 12:18 AM
cris's Avatar
well i had the consol out because im wireing power windows and locks and puttng the controls on the consol, so it wasnt a big deal that i had it out- now i know exactly where your talking about, i was looking at that asking my boss what that switch was with those wires running to it last week when we had the car on the lift, my tranny was making noise and we found out it wasbecause the guy who changed the clutch befor i had it only put 2 bolts back on and didnt tighten them- 2 bolts and an hour later it was running great, well thanks for your help- ill go to the shop tomorrow and see what i can do about that switch
Old Feb 8, 2003 | 09:09 AM
Car: '91 Z28
Axle/Gears: 323's
yep, you're right... i was thinking of an auto - next time i'll pay a little more attention...
KAM
Vintageracer
Jan 10, 2020 05:33 PM
justin57
Aug 20, 2015 07:05 PM
tnrednneck
Aug 13, 2015 08:57 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
Omega
Aug 10, 2015 12:46 PM
