Viper 300
Old Feb 9, 2003 | 04:41 PM
icarus402001's Avatar
Viper 300
I got my 92RS last April and it had a Viper alarm in it. Recently, I dropped the remote and it took a dump. I cannot find an installation manual on DEI's website. They have the 300 listed but it gives me the manual for the 300HF. They list two other 300's but they aren't right either. Does anyone have the install manual for the 300? It's probably 8 or 10 years old.
Old Feb 10, 2003 | 01:22 AM
lane's Avatar
What exactly are you looking for in the installation manual? I've been doing DEI alarms for about 10 years, and they have not changed much.
Old Feb 10, 2003 | 05:28 AM
I'm trying to locate a wiring diagram and programming instructions . I don't completely trust the installation, going by the drawings I've seen from the later models. I'm questioning the wiring of the valet switch ,mostly. If you have a wiring diagram, my email is Kszczepans@aol.com
Old Feb 10, 2003 | 07:51 AM
Z28DJP1987's Avatar
That valet switch is junk, either don't use it or remove it.
Old Feb 27, 2003 | 11:47 PM
89IRO's Avatar
Opinions on the DEI, rattler 300? I think it was like $107 at circuit city. Quality? Opinions?
Old Feb 28, 2003 | 01:24 PM
Steve89GTA's Avatar
This is a long shot but, I have a clifford alarm (model says 2020 on it and it is cream coloured). After i got the car back from the body shop, the LED just stays lit and blinks a little. The remote doesn't do anything and neither does the valet switch. Is it fried?
Thakns for any help. I've checked the wiring and it looks fine. Alarm came with the car so I don't have a manual or anything. My next bet is to take it out and hook it up to a power supply and see what happens..
Old Mar 1, 2003 | 01:38 AM
2vmodular's Avatar
You've got the right idea: yank the old alarm from the car and install a new one in it's place. All the harness wires should already be tapped so the install should be quick & easy.
Old Mar 1, 2003 | 01:08 PM
joezero's Avatar
Car: See pic above
Engine: Too Small
Transmission: Broken
Could it be in valet mode? If I remember correctly, if you press button one then two then one again within like 1 second of each other it activates/deactivates valet mode. I accidently did this while trying to troubleshoot a no start problem. I thought maybe the ignition kill had failed and wouldn't let it start. I accidently put it in valet mode and then it wouldn't arm/disarm and the LED did something similar. I thought I'd fried the module until I pulled out the manual and realized it was in valet mode.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
no green
Jan 9, 2016 09:22 PM
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
Royal_Z
Sep 30, 2015 08:45 PM
david068513
South East Region
Sep 13, 2015 11:24 AM
