anyone ever hear of this?
Old Feb 12, 2003 | 07:41 PM
jeffsbluez's Avatar
Car: 91 z28
Has anyone ever heard of this. When my buddy turn his distributor (with the key on but the car not running) his fuel pump turn on and the injectors start letting fuel in the cylinders. If he disconnects the fuel pump relay it stops. If he disconnects the wire from the back of the distributor it will also stop. Also ,as a side note, his car is dumping way to much fuel at idle. PLEASE HELP
Old Feb 12, 2003 | 08:19 PM
84Z28_5.7ltr_V8's Avatar
Car: 1984 Z28
no offence but..
rephrase that in english!
Old Feb 12, 2003 | 08:35 PM
jeffsbluez's Avatar
Car: 91 z28
Ok here we go. With the car off and the key on the fuel pump primes itself. This is normal. He was working on the car and accidently turned his distributor. The fuel pump turned on again. He then turned it again to see if the pump would do this again. It did Is this normal or do you think he has a wiring problem?
Old Feb 12, 2003 | 08:39 PM
Car: 1984 Z28
so.. what your saying is,basically, that he literally turned the distributor, and now the fuel pump does.. what? primes itself??? well you just said that that was normal but i dont think its a good idea to turn the distributor!! how much did he turn it!?
Old Feb 13, 2003 | 04:07 PM
jeffsbluez's Avatar
Car: 91 z28
You are correct. He moved the distributor a good bit. Every time he touches the distibutor, the fuel pump turns on. I do not think this is normal. He thinks this is the cause of his fuel problem. Hope this makes sence to you. Thank you for your time.
Old Feb 13, 2003 | 04:18 PM
Jza's Avatar
Jza
It sounds normal. The ECM triggers the fuel pump relay and injectors whenever it receives distributor reference pulses, which you're basically manually doing when you turn the distributor.. Although admittedly I've never cranked it around enough for it to do that with the key on...
Is he TBI or TPI?
Old Feb 13, 2003 | 04:21 PM
jeffsbluez's Avatar
Car: 91 z28
TPI. I don't know why he is turning it , but he thinks it is a problem. Thank you for your info.
Old Feb 13, 2003 | 04:38 PM
Jza's Avatar
Jza
How's his CTS reading look? An incorrect reading could lead the ECM to think it needs extra fuel. It could also be a sticky injector (the extra fuel wouldn't be apparent at anything past idle). That could be expanded to include the cold start system if equipped.
A scantool could help your buddy out immensly.
Old Feb 13, 2003 | 05:58 PM
patrickm00's Avatar
he may also have some leaking injectors as well, if you hear fuel being sprayed/dripped into the cylinders when you're not moving the distributor.
Old Feb 13, 2003 | 06:37 PM
jeffsbluez's Avatar
Car: 91 z28
Fuel is leaking only when the pump cycles a couple of times
Falcon50
Aug 22, 2020 03:26 PM
92projectcamaro
Dec 8, 2015 12:25 AM
Fanatic1074
Oct 2, 2015 03:47 PM
sjorgens
Oct 1, 2015 07:54 PM
thejimsterz28
Sep 30, 2015 08:52 PM
