MSD box temperature
Old Feb 17, 2003 | 06:06 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
MSD box temperature
I'm in the process of mounting my MSD digital 6+ box, and was curious as to whether the heat generated by it will be enough to affect intake air temperature..
Here is a mock up pic of where I plan on mounting the box:
Any ideas?
Old Feb 17, 2003 | 06:08 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I would seroiusly doubt it.
Old Feb 18, 2003 | 01:27 AM
383 rocket bird's Avatar
It should be fine there. I seriously doubt any heat generated from the ignition box could affect air inlet temperature in any way.
Old Feb 18, 2003 | 10:24 AM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
OK, just making sure.
I've felt other ignition boxes after some driving, and they get pretty damn hot..
Old Feb 18, 2003 | 10:51 AM
Mounting the box there is also a pretty good idea because you are supposed to keep them away from heat and that ought to help keep it as cool as possible.
Old Feb 18, 2003 | 02:40 PM
IROC57TPI's Avatar
I got mine next to the battery and have had no problems in over 2 years.
Old Feb 18, 2003 | 04:36 PM
fattie92's Avatar
i had mine over by the batt as well.... that sucker got so damn hot i was affraid to leave it there!.. so i moved it inside the car, and it doenst get nearly as hot in there. If you want to keep that box working for a long time, i say move it inside.
$750 L98
Feb 1, 2025 02:25 PM
codeysabatini
Nov 10, 2015 04:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
tattmann
Sep 27, 2015 05:20 PM
Dragonsys
Sep 25, 2015 03:51 PM
