Rudementary Electronics Class
Old Feb 19, 2003 | 01:12 PM
scanman717's Avatar
Car: 92 Z/28 Convertible
Engine: LB9
Transmission: Mad Dog Auto 700R4
Ok, I know this is basic, but....
1. What is the Amperage that you get from the cig lighter??
2. I need to convert 12-14v and whatever amps the cig lighter outputs to: 6v, 300ma. Unfortunately, I can't remember a damn thing from electronics class... I am assuming I just need the right combo of resistors
Old Feb 19, 2003 | 01:36 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A resistor isn't the right way to go, you'll need a 6 volt regulator.
Old Feb 21, 2003 | 10:17 PM
racerx004's Avatar
If you don't mind me asking, what do you only need six volts for?
Old Feb 22, 2003 | 06:54 PM
scanman717's Avatar
Engine: LB9
An MP3 Player...
I don't listen to it often in the car, but when I do, I go through batteries fairly quickly...
I have a Cell phone, MP3 Player, GPS unit, Palm Pilot and a laptop that I use at various times during long trips, and it is a real pain in the a$$, to cary all those car cables, expecially when you are running more than one item at a time. I am trying to make a "all-in-one" adapter, so that I have one unit plugged into the cig lighter, a and be able to power a couple of things at the same time.
Anyway, that is the plan.. I was able to get a cable cobbled together that will recharge the palm and run the GPS at the same time....
InfernalVortex
Apr 20, 2021 11:31 AM
MrPackstin
Oct 25, 2017 08:09 PM
1992Z28!
Nov 19, 2015 07:33 AM
anesthes
Sep 30, 2015 07:48 AM
scottmoyer
Sep 7, 2015 07:06 PM
