Cruise control not working?
Old Feb 19, 2003 | 09:05 PM
87z28camaro's Avatar
Car: 1987 Z28 Camaro
Engine: 305 tpi
My 87 camaro cruis control is not workin, when i bought it it did not work, hoever it has the unit and all, just dont work, what do i check to see what i need to do to it? and how do i fix it haha, im stupid at mechanic stuff, and any help will help, thanks
Old Mar 29, 2003 | 01:44 PM
badredbrd89's Avatar
I'm trying to find out the same info here-but I have an 89 Formula with LB9 motor. let me know if you fiond anything out-jimi_76@hotmail.com
Old Mar 30, 2003 | 06:10 PM
vulchr's Avatar
Had the same problem with mine, checked everything and it turned out to be the vacuum hose that goes to the Brake Pedal Switch/Valve at the top of the brake pedal, it had worked its way loose so i re conected it and what d ya know?, It worked again.
Old Mar 31, 2003 | 12:14 AM
2vmodular's Avatar
The wires that run into the turn signal stalk on the steering column often break on older general motors products. I've got a couple "pre-owned" spares around if you need one, they list for close to $100 at the dealer.
eightsixseven
Dec 16, 2024 01:50 PM
Street Lethal
Aug 13, 2015 08:28 PM
stalkier
Aug 13, 2015 12:59 PM
Street Lethal
Aug 12, 2015 11:33 AM
Bull86
Aug 10, 2015 05:43 PM
