Change My Alarm To HighBeams???
Old Feb 23, 2003 | 01:24 PM
SuperchargedRS's Avatar
Car: Camaro of course
Ha anyone here seen then independent film "The Last Race". if so during the scene where he's leaving the diner, he dis-arms his alarm and instead of his parking lights fllashing and his car chirping at the same time, his car chirps twice, than about 1/2 second later his inner high beams flash twice (Ac. Intergra). Since the Ac has the same kind of lights as us (inner & outer), how would one do this mod. Oh yea I also have remote start, so I would want them to flash once before the start.
Alarm: Clifford Matrix
Lights: outer: HID, inner: scraped Halogens
Car: 89'RS
*I have a few ideas on this, but I want to know what you guys think would work best
THANKS
Old Feb 23, 2003 | 08:52 PM
360Iroc's Avatar
its just the way your wire it...i have a question because i am researching the topic ...tell me about your HIDs in your lows that what i want i dont car about the high beams
Old Feb 24, 2003 | 05:30 AM
Uhh I guess you mean why aren't my high's HID, well I had the h4 conversion for my head lights, I put the hids in my lows because they are the only lights that are legal on the car and I the few times the Camaro is on the road it's night time. My highs are...I forgot the make, but if you look at a halogen they have a painted tip, I carefully scraped the paint all off. The way my highs work are as a tactical floodlamp (dont ask). As far as that goes I have never looked head on w/ the highs on, if that's a guage if brightness. I also modded dubble rev. lights one that is just the normal LED white bulb, the other is a scraped halogen bulb wired the the right button on my wheel (dont ask).
Old Mar 1, 2003 | 01:44 PM
joezero's Avatar
Car: See pic above
Engine: Too Small
Transmission: Broken
You would just cut the wire the parking lights at the alarm. Then wire in a relay that would send power to the high beams. There should be a relay for the high beams somewhere, so you could just run the parking light wire to that. I did something similar to this so that the undercar lights flash along with the parking lights when I arm/disarm the alarm. If you want the parking lights and high beams to flash, you'll need to isolate the circuit, or else whenever the parking lights were on your high beams would be as well. But if you just cut the wire to the parking lights then it wouldn't be a problem.
86CamaroDan
Sep 29, 2015 10:08 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
FormulasOnly
Sep 6, 2015 10:42 AM
luvofjah
Sep 3, 2015 07:08 PM
