Clear Radio Reception/Static W/engine on??
Old Feb 23, 2003 | 11:43 PM
PhantomTPI's Avatar
Car: 1986 Pontiac Trans Am
Engine: 5.0 TPI
Ok....this might be a dumb question, but I just have to know what this is....with my motor off, and my key in the bottom most position(radio on only), i get CRYSTAL CLEAR reception on my radio. If i dont move the car from that spot, and I turn the engine on, i get static, and can barely make out the radio/songs/etc that are comming in on that station. So my quesiton is...what causes this, and how do i remedy the situation? Any takers? Thankx.
Old Feb 24, 2003 | 11:02 AM
kptkid's Avatar
could be lots of things but check spark plug wires and check ground at the battery to the frame.
Old Feb 24, 2003 | 03:07 PM
PhantomTPI's Avatar
Engine: 5.0 TPI
Spark plug wires are ok, and ground to the frame is good. The only thing about the wires is that they arent held together on those wire "collectors" or whatever you call them that just organizes them and sets them side by side....i wouldnt think that would make a difference...what else could it be?
Old Feb 24, 2003 | 04:19 PM
firebirdchick24's Avatar
my radio does the same thing, i think its my radio cuz it did it in my old car too...i'm gonna try to replace it soon. but you could always get a noice reducer for the stereo...that works
Old Feb 24, 2003 | 04:57 PM
PhantomTPI's Avatar
Engine: 5.0 TPI
April...
Thanks for the tip Is that something that I would get at, say a car installation place? And where would I install something like that? My radio is out of a 98 Grand Am GT....so it should be "strong" enough to get the reception that I would want. Thanks.
Old Feb 24, 2003 | 06:16 PM
jwattsjr's Avatar
Car: 84 & 86 T/A
Engine: LT-1 & 5.7L
Transmission: 700R4's
You might want to check the antenna. I had similar symptoms, and it turned
out to be a loose antenna base.
Jeff
Old Feb 24, 2003 | 06:28 PM
Originally posted by PhantomTPI
April...
you can pick one up at walmart...very cheap...you hook it up to the back of the stereo wires...simple to install
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RS Reaper
Oct 17, 2018 07:52 PM
Fireslash
Apr 11, 2016 06:43 PM
Gunner242
Dec 25, 2015 04:49 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
