swaping throttle bodies, need throttle position sensor help!!_please help
Old Mar 3, 2003 | 07:46 PM
sonomakid's Avatar
the throttle body on my '88 firebird started leaking gas, so i switched it with another throttle body, but the new one has a triangle shape plug for the throttle posisition sensor, mine had a flat plug, with the three wires in a line.
I don't have the plug from the new throttle body so i'm not sure which wires go where.
My wiring harnes has a black, gray, and a dark blue wire going to this sensor located on the front passenger side of the throttle body.
So if anyone can help, i would really appreciate it.
Thanks A Lot
Patrick Clark
Old Mar 4, 2003 | 11:09 AM
sonomakid's Avatar
still scratching my head...please help__
if someone with a throttle body with one of those round plugs, for the throttle posisition sensor, could tell me which wires go to what, i could probally figure it out.
the three wires are in a triangle shape in the round plug.
so if anyone could help me out, i would really appreciate it.
Thanks Again
Patrick Clark
Old Mar 5, 2003 | 06:37 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I don't know the pin relation between the two. Easiest would be to go to the junkyard and get a new connector or get one from you local parts store.
Here is a drawing of the wires on my 91 tps.. might help.. might not...
Attached Thumbnails swaping throttle bodies, need throttle position sensor help!!_please help-tps.gif
9192camaro
16
Feb 3, 2019 12:21 AM
stalkier
Dec 6, 2015 11:25 PM
hayesaw0210
Aug 23, 2015 11:15 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
