350 TPI cranks forever
Old Mar 8, 2003 | 03:16 AM
BhodiLi's Avatar
I am not sure what kind of problem i have. At first i thought it was the battery or lines, maybe starter?
When i crank the engine i can hear it trying to turn over, but it won't catch on the first try. Ever. It'll crank, and then if i try again it will crank for awhile and then catch. Then it would even crank. I changed out the battery cables and retimed it and it went back to the old problem, don't know if this was related or just another part that wore out. I thought at first it might be the starter, i had to replace one before on my 88 IROC. This by the way is an 85 Z28, with a crate 350 TPI. Could this be bad injectors? I don't know much about the TPI. Any thoughts would be appreciated cause nothing is worse than sitting in a parking lot while me girlfriend laughs at me spending 5 minutes starting my car.
Ok, I am an idiot, although in my defense it is 3 in the morning here. I just saw the general help board and will now post this there.
Old Mar 8, 2003 | 11:22 AM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
i think i know
i think it has soemthign to do with the throw out gear on your starter if i were you id buy a new starter for the beast.
Old Mar 8, 2003 | 09:16 PM
Breadfan's Avatar
If it cranks and won't start , then make sure you have spark and fuel .
Old Mar 9, 2003 | 12:55 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
Yeah, definitly check for fuel.
The '85 TPI's used a cold start injector to start the car when the engine is cold. It's located on the driver side intake runner. It is plumbed in between the 2nd and 3rd runner tube. Make sure you have one. If you do it may be bad.
The cold start switch could also be bad. It is a sensor located at the front of the intake manifold right near the coolant temp sensor.
The fuse could be bad. Look for a fuse labeled "crank". That fuse provides power to the cold start injector.
Check the fuel pump relay too. Watch your oil pressure. If it starts to want to start when there is pressure or when pressure is building the relay is probably bad. In the event of the fuel pump relay failing the ECM will turn the pump on only if oil pressure is present.
I had the same problem, my girlfriend also laughed at me when I tried to start my car.
Hope this helps,
Matt
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
