Does The Speedo Sensor In A 91z28 Have A Fuse??
Old Mar 16, 2003 | 10:59 PM
91 Camaro Z28's Avatar
My speedometer in my 91 Z28 isnt working-- is it possible that i blew a fuse or something? i checked the connection at the tranny and its good- any ideas??
Old Mar 17, 2003 | 11:26 AM
Jza's Avatar
Jza
No. The VSS is a permenant magnet generator, so it basically makes it's own power (loooosly speaking).
Exactly what did you do to check the connection? Just made sure it was plugged in, or did you test/trace the wires to the ECM?
And just because the wires connect doesn't mean the unit itself isn't creating a signal.
Veryify on a scantool that the ECM is getting a signal. If it's getting a signal, but your speedometer is still not working, look for a break between the speed output at the ECM to the speedometer.
Old Mar 17, 2003 | 11:51 AM
I thought the cable might be something else, so i physically connected the prongs together to "complete the circuit" i think i messed it up or something, because before it worked fine..
Old Mar 17, 2003 | 03:28 PM
Jza's Avatar
Jza
Ew. I'm not sure that hurt it, but that's a really dumb thing to do. Generally electronics need to see some type of load. The technical term for something directly connected across like that without a load is a "short".
But in this case (an AC motor creating this speed signal) that may or may not hurt it. If you're indeed missing your drive gear like your other post seems to indicate, that might be your problem. If you did hurt something in the ECM, then consider it a $30 lesson in crossing wires. Should be about that much to pick up this very common ECM from a yard or auction of some sort.
Old Mar 18, 2003 | 08:03 AM
where can I get that drive gear and what is the process of putting it in etc.. do i need it out of the auto tranny? how does it go in?
Old Mar 18, 2003 | 12:01 PM
Jza's Avatar
Jza
Last time I got a drive gear from a Chevy dealer it cost me about 4 or 5 bucks. You'll have to take the tailshaft off to get to the output shaft. That usually requires disconnecting the torque arm and catalytic converter mounts which may or may not need removal of other things to make room. The driveshaft has to come out, too. Then you squeeze or remove the metal retainer clip and slide the gear off the shaft. Same process to install, and make damn sure that the gear is on in the right place and will NOT go anywhere, because it's fairly common for it not to be installed quite all the way and it'll slide up or down the shaft and either disengage from the driven gear, or get chewed all to hell.
I don't believe the auto and manual gears are interchangable, but it HAS been a while since I've messed with the electric VSS's, so don't take that as gospel.
Old Mar 18, 2003 | 12:14 PM
Jza-- thanks for your help- i'll have to call around the local chevy dealers and see if they stock the part- drive gear for 91Z28 T-5-- got it THANKS!!:hail:
Old Mar 19, 2003 | 01:34 AM
Odyssey's Avatar
Did you check the ECM fuse ? The ECM processes your VSS signal. If the ECM doesn't work, then your speedo doesnt work
Old Mar 19, 2003 | 09:50 AM
Jza's Avatar
Jza
Car wouldn't even run, then..
Old Mar 20, 2003 | 09:16 PM
Odyssey's Avatar
True... I was thinking of my carburated setup! lol
GTAman
Jul 3, 2024 07:29 PM
gta892000
Aug 11, 2019 11:16 AM
gta892000
Sep 16, 2015 12:37 AM
TrevinE
Sep 14, 2015 03:20 PM
timonator
Sep 10, 2015 07:55 PM
