Can't pull any codes at all (not even code 12)...
Old Mar 17, 2003 | 03:29 PM
sancho's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
This is on the '89 IROC in the sig.
I read in the FAQ about how to read codes from the computer using the flashing SES light. I decided to give it a try; first I tried to short pins 6 and 12, and then I tried 5 and 6. Each time after I shorted some pins and turned the key, I didn't get any flashing lights at all. Everything just happened like I didn't short anything at all--I could hear the fuel pump come on, and the "Fasten Seat Belts" and "Security" lights came on, and then went off.
I should note that this car has a Viper alarm system installed in it, and I can tell under the steering wheel where there has been a lot of (messy) electrical work. I don't know why any part of that alarm system would tap into the diagnostic circuit, but I just thought I'd mention that.
Any ideas why I can't pull any codes? Is there anything that I can check with a standard multimeter to see if the diagnostic circuit is good?
Wiring diagrams are always helpful, too.
Old Mar 17, 2003 | 04:14 PM
patrickm00's Avatar
turn the key to the 'run' position without starting the car. if the service engine light still doesn't come on at all - even solid- then replace the bulb.
Old Mar 17, 2003 | 04:30 PM
sancho's Avatar
patrickm00: I should have thought of that!
I did what what you said, and sure enough, the light doesn't come on at all. The only lights that come on are the Fasten Belts and the Security lights. My daily driver is an '88 Camaro and it has a SES light but no Security light; I guess I just assumed that the SES light was replaced with the Security light in '89 (what is that security light for, anyway?).
Hopefully it's just a bulb, and hopefully I won't have to dig too deeply into my dash to replace the bulb.
Old Mar 17, 2003 | 05:00 PM
patrickm00's Avatar
the security light is for VATS
nope, it's not that big a deal. just a few screws for the dash pad, then a few more for the plastic panels.
Old Mar 17, 2003 | 11:23 PM
sancho's Avatar
Well, I got the gague cluster cover panel off. It was just eight screws around the perimeter--didn't even have to remove the dash pad. Turns out, there wasn't even a bulb in the SES socket.
Old Mar 18, 2003 | 05:18 PM
patrickm00's Avatar
that's always a sign of a well-cared for car and a conscientious seller...
Old Mar 18, 2003 | 06:36 PM
sancho's Avatar
There may have been a reason for that; see here .
chazman
Aug 28, 2018 03:25 PM
86IROC112
Aug 31, 2015 07:00 AM
chazman
Aug 22, 2015 02:01 PM
GouldyGTR
Aug 21, 2015 10:43 PM
