Bought new alt, doesn't fit, right year!
Old Mar 22, 2003 | 09:33 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I just bought a PowerMaster 140amp alternator from Year One, and the description was as follows:
<p>
1988-1992 5.0/5.7 TPI motors. Simple 3 wire plug connector.
<p>
I have a 1988 Iroc with a 5.0 TPI, and my alternator has the two mounting holes on the lower half about 100 degrees apart. The one that was sent to me has them directly across from eachother. When I called they swore that it was the right alternator. What's going on??
Old Mar 22, 2003 | 10:07 AM
smokingss's Avatar
send it back say it doesnt fit, sometimes parts get switched up, or the wrong front case plate was installed, it happens. exchange it...year one should have no problem with that...if they do, id never buy from them again
Old Mar 22, 2003 | 10:11 AM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
A) they could have sent you the wrong part (check the PN stamped on to the part, the box could have been switched)
B) The alternator that you have now along with its mounting brackets could have been added on, either because the previous owner got the wrong alternator or had one lying around and decided to use it. (This is not too likely)
C) It could be that the mounting system you have must be modified to allow the alternator to fit properly.
If the alternator said "direct fit" in the part description, then check the bracketry, and if it don't work, send it back.
Old Mar 23, 2003 | 07:35 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Well, guess it's back to the old one for a while! What years are your cars, and what does the mounting look like? Mine looks like the attached pic.
Old Mar 23, 2003 | 11:57 AM
Morley's Avatar
It is probably the right P/N for your car but the case is clocked wrong. Every time I get an alternator I have to re-clock the case to use it, no biggie.
Old Mar 23, 2003 | 04:44 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
...re clock... you lost me ;)
Old Mar 23, 2003 | 05:12 PM
VERTIGO Z28's Avatar
Car: FBODYS
Engine: ALWAYS 8'S
Transmission: ALWAYS MENTAL
Axle/Gears: RUSTY AND BRAND NEW
re clocking
loosen the 4 alt case screws rotate the case to where you need it and if it still dont work swap out the rear case
Old Mar 23, 2003 | 06:08 PM
Morley's Avatar
You'll have to remove the 4 bolts/screws that hold the 2 halves together, remove the back half, put the brushes back in the holders and hold them there with toothpicks through the holes in the case (you'll see them) by the brushes. Then put the alt together with the mounting holes in the proper position for your mounts and reinstall the bolts/screws.
Old Mar 23, 2003 | 06:37 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Re-clocking won't fix this. Usually the mounting holes are both on the same case half, so "re-clocking" won't do anything but orient the plug and any support holes.
Most 140 amp alternators have the holes 180° from each other, but you can still make it fit! Here is an article showing how:
Installing a 140A Alternator
EDIT: The article mentions use of a longer belt, but I have had several people tell me that the stock belt worked fine.
Old Mar 25, 2003 | 05:28 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Well, I called Year One and they had no idea what was wrong. On the back of the alternator was a paper tag that has the right part # on it, so I was just as confused. I called up PowerMaster, and described it; they told me it is a Corvette alternator (also fits the 454 SS pickup) Shoud I send it back to get a replacement, or is this one worth more than the one I bough, and I shoud sell it?
Old Mar 25, 2003 | 05:35 PM
rezinn's Avatar
Send it back unless you want to do what GMTech posted. The bolt holes need to be something like 135 degrees apart to fit on the serpentine bracket we have on our cars.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
86IROC112
Sep 7, 2015 01:37 PM
TheJoeY88
Aug 13, 2015 06:51 PM
3rdgenparts
Aug 5, 2015 11:57 PM
