Headlight problems
Old Apr 14, 2003 | 06:26 AM
who5252's Avatar
Headlight problems
Hi everyone.
Just bought a 91 Camaro. Love it so far, but have a couple problems with the headlights. Thanks in advance for any help.
I was driving the other day. (First time in the dark) Realized you had to hit the wiper switch pretty hard to go from low beam to high. That is the first question. What needs to be replaced to make that easy again. Just the switch or more? Next, I switched to low beam and they were completely off. High beam works perfect, but no low beam at all. Just was wondering what to do about that. I got flahed about 10 times on the way home, but not much I could do!
Thanks!
Old Apr 14, 2003 | 11:28 AM
Drunken_Polak's Avatar
well...i got the same problem with the switching high to low I think its just the switch but ill keep my eye on this thread for the answer from a more reliable source ...but for the headlights....1st check if wiring is all well connected... then u should chech if they are burnt out or not....after that....well....i dunno...maybe somebody else could help you out after that
Old Apr 14, 2003 | 03:09 PM
who5252's Avatar
Ya,
I am going out to check that right now. I don't think it is that thought because they were working fine until I switch high then back low beam. Crossing my fingers though. Anyone have an ideas?
Old Apr 15, 2003 | 11:45 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
sounds like it could be a relay,maybe?
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
