car won't start
Old Apr 23, 2003 | 08:58 AM
jasman19's Avatar
Car: RED 1986 IROC-Z28
Engine: 350 5.7L
Transmission: TH 700R4
Axle/Gears: 3.23 10 Bolt
car won't start
I have an 86 IROC, the car will crank but won't start. I found that my fuel injectors are not pulsing like they should. I checked my fuses and they are ok, my spark is good so my ignition is working. I changed out my ignition module but that didn't change anything. I am pretty sure that I don't have VATS on my car. I don't have a resistor in my key, my key is some run of the mill crap. Tonight I am going to try and swap my ecm, not sure what else to do. Also I am getting fuel pressure in my rails, just my fuel injectors won't work. They are brand new accel injectors. P lease help if you can!!!
Old Apr 23, 2003 | 02:23 PM
1986tpiiroc's Avatar
Car: 1986 IROC-Z
Axle/Gears: Dont know yet
I have an 86 IROC also. You might wanna check to make sure your getting fuel pressure. Mine did that 2 weeks after i bought it turns out the fuel pump took a crap on me. And no 86s did not have VATS, I think VATS came out after 88 or 89, not sure though. Hope you get it runnin again.
Old Apr 23, 2003 | 02:25 PM
Car: 1986 IROC-Z
Sorry, should of read more, im an idiot, i guesss you are getting pressure. Next would be to check injectors i guess.
Old Apr 27, 2003 | 10:43 AM
jasman19's Avatar
Engine: 350 5.7L
I just checked my ECM and the resistance from A6 (power in) to the injector banks was 1. I think this means that there is no connection between these two prongs. I dont know what else to do. Next I'm going to try to burn a new prom without any vats on it. Any help would be nice!!!
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
