HELP My washer fluid does not work!!!
Old Apr 23, 2003 | 04:15 PM
mace87's Avatar
HELP MY Washer Fluid Does Not Work!!!
I have looked over the way the thing works, Is it connected to the vacuum or something. I see the electric going into it it but nothing comes out when you push the button in, inside the car. and yes fluid is in the washer fluid container. I could really use some help, so if anybody knows how to fix this peice, please let me know.. Thanx.. Mace87
Old Apr 26, 2003 | 06:25 PM
mdr211's Avatar
Car: 86 camaro Z28
Engine: 305 carb
the same thing happened to me, i just went to the junkyard and got a new washer pump assembly and replaced it and everything works fine now...im talking about replacing the whole assembly and not just the little pump itself... what i did first was i bought a new pump(the long, circular thing that sticks out the bottom of the assembly holds the pump) and that didnt fix the problem and when i replaced the main assembly everything was fine...
Old Apr 26, 2003 | 07:02 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Try the pump first, they cost about $12.00. Unless you want a small job turn into a big one.
Old Apr 28, 2003 | 04:48 PM
mace87's Avatar
thanx
Hey thank you for your help, it is greatly appreciated!:hail:
ZMWojnar
Brakes
May 12, 2019 10:43 PM
backtothe80s
Sep 5, 2015 12:39 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
