cruise control don't work
Old Apr 23, 2003 | 04:58 PM
blackknight2010's Avatar
Car: 85 Transam
Engine: 305v8 carburetted
Ever since I got my 85 transam, the cruise control has never worked. Fitted a replacement cruise control switch / turn signal lever, checked the wiring under dash, the relay can be heard clicking.
Where do I go from here to determine the fault ?
Thanks for any help.
Old Apr 27, 2003 | 10:01 PM
BigTiggBoy's Avatar
Car: 1986 Trans Am, 1997 Trans Am WS6
Engine: 5.0 Liter TPI, LT1
Transmission: 700R4, T-56
Axle/Gears: 3.27 9-bolt, 3.42 10 bolt
You need to check the servo to see if it is functioning. Disconnect the cable that runs from the servo to the throttle body. You have to build up vacuum so start the engine and run it for about a minute, then turn it off. With the ignition switch in RUN, and holding Cruise Switch in R/A, press and release the Set Switch. If it is functioning correctly the vacuum should hold the servo at wide open throttle position. If it is ok, I would then check the vacuum release valve at the brake pedal. Hope this helps.
Ghettobird52
Jul 5, 2024 11:18 PM
colton_carlson
Mar 8, 2019 12:21 PM
Street Lethal
Aug 13, 2015 08:28 PM
Street Lethal
Aug 12, 2015 11:33 AM
Bull86
Aug 10, 2015 05:43 PM
