Relays
Old May 10, 2003 | 04:23 PM
warrior_91's Avatar
Car: 86 T/A
Transmission: 700-R4 Auto
Relays
My headlights dont go up or down because when I bought the car as is, someone ripped out the 2 relays and isolation relay for the headlights. I know my motors arent shot because I ran power from my battery to the wires running straight from the motors. So my question is that there are plugs on each side of the motors that the 2 relays plug into. I know where those relays go. But what does the isolation relay look like? I did find about 4-5 wires that were near my battery that were cut off from something? Is that where my isolation relay goes?
86 Trans Am, 5.0L, 305, 4bbl, True Dual Exhaust
Old May 10, 2003 | 05:45 PM
jwattsjr's Avatar
Car: 84 & 86 T/A
Engine: LT-1 & 5.7L
Transmission: 700R4's
All three relays look the same. On my 86, two were mounted on the inner fender, near the top,
behind the battery(pass. side)/cruise(driver's side) tray. The third one was mounted next to the
radiator, in front of the battery.
As I said, they all look alike, but I don't recall if they all have the same p/n.
-Jeff
Edit: I went and checked, and they're not all the same. Two of them are (the ones on the fenders) but,
the one on the radiator support is a little different. I took some pics, but my good camera is at work.
So, you'll have excuse the quality.
-Jeff
Old May 10, 2003 | 06:47 PM
jwattsjr's Avatar
Car: 84 & 86 T/A
Engine: LT-1 & 5.7L
First, the driver's side...
Old May 10, 2003 | 06:48 PM
jwattsjr's Avatar
Car: 84 & 86 T/A
Engine: LT-1 & 5.7L
Passenger side...
Old May 10, 2003 | 06:51 PM
jwattsjr's Avatar
Car: 84 & 86 T/A
Engine: LT-1 & 5.7L
And the last one. The numbers I found on 'em were 1003124 (for the two on the fenders) and
14078915 for the one pictured here.
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
