Bad switches, need to roll windows up
Old May 24, 2003 | 12:07 PM
Ovrclck350's Avatar
First one switch went out and I've been switching it back and forth till I could get a new one, but now the other one is lost. Is there any way to jumper them or anything to roll them up? I've looked at all the parts stores and they don't have a switch at all like the power window switches we have.
Old May 24, 2003 | 02:54 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
You could probably jump it. Take the switch apart and look at how it works. All it does is slide to metal pieces to make the connection.
Matt
Old May 24, 2003 | 03:34 PM
MasterEvilAce's Avatar
there are four connections on the switch... if you hold it so the four are facing closest towards you, i imagine if you jump the two that are away from you, it will roll up.
the two closest to you, and it'll roll down.
Just a guess.
Old May 24, 2003 | 04:30 PM
Ovrclck350's Avatar
Hmm...tried the 2 top ones and the car died. NO window action.
Old May 24, 2003 | 05:32 PM
that's... weird...
Old May 25, 2003 | 05:22 PM
Ovrclck350's Avatar
Figured it out
You connect the left 2 together and the right 2 together to roll UP Or Criss Cross top left/bottom right top right/bottom left to roll down.
Old May 26, 2003 | 09:08 PM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
Originally posted by Ovrclck350
Figured it out
yeah.. what he said
Old May 26, 2003 | 09:21 PM
that combo seems a bit retarded, and unlogical... MEH1
Old May 29, 2003 | 08:22 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
no it doesn't, there are two wires coming in, a power and a ground, two wires out, to the window motor, you need power on one wire to the motor and ground on the other, the reverse for the other direction
Old May 29, 2003 | 11:24 PM
yeah but i mean like
you could just have the top wires at the top that need to be connected to go up
and the two others on the opposite side
so when you push the switch forward: connection
push it back: connection
instead of having the diagonals connect
Old May 30, 2003 | 06:07 AM
Dave Y's Avatar
Engine: 4.3L V6
no, wouldnt work, you would only be connecting one in to one out, you need to connect two ins and two outs and also reverse them for it to work
Old May 30, 2003 | 04:00 PM
blah
Vintageracer
Jan 10, 2020 05:33 PM
evan555222
Sep 20, 2016 02:51 AM
neekolzun
Aug 24, 2015 04:59 PM
Dialed_In
Aug 20, 2015 01:45 PM
Wylecoyote08
Aug 14, 2015 08:28 AM
