Tach in 87 IROC / 305 TPI
Old May 30, 2003 | 12:32 AM
BrianChevy's Avatar
Car: 1987 IROC Z/28
Engine: 5.0L TPI. Custom Tune
Transmission: 5 Speed/ Pro5.0 short /hurst stick
Axle/Gears: 1LE 10 bolt Rear/T2R 3.45 PBR/disc
Dear friends,
I have done some searches and found that lots of you are trying to put aftermarket tachs in these third gen camaros. I didn't find alot of answers on my searches thru the archive, but, I was able to get thru it. SO, I've decided to post this quick
HOWTO INSTALL AN AFTERMARKET TACH IN A 1987 thirdGen in the hopes it will help some of you.
1) Disconnect battery
2) Remove Vanity plate over distributor
3) Find the external coil, it should have 2 connectors on it.
4) Remove BOTH connectors, don't worry they are keyed and only go on 1 way. (you have to pull a retainer to remove the clip)
5) Find the GRAY connector with the pink wire and the white wire
6) Clip the white wire. somewhere in the middle.
7) Reconnect the coil connectors BOTH OF THEM.
8) Reconnect the battery and start the car. You will notice that the old crusty stock tach NO LONGER WORKS BUT THE CAR RUNS.
COOL, eh?
9) If you have removed the airconditioning vents in the center dash, install the tach (mine is an Autometer Monster Tach with shift light). Run the wires down thru the dash to the firewall, find a hole up around the master brake cylinder.
10) Hook the RED WIRE to the IGN plug in the fuse panel, it will need a male connector on the end to plug it in.
11) Hook the Black wire to the ground (i used the bolt at the far left under side of the dash with a nice extra washer)
12) Run the green wire thru the firewall and up to the COIL. Be sure and protect it well (i used some 1/4 inch rubber tube to ensure it didn't rub on the firewall.)
13) Strip and attach this green wire to the STUB OF THE WHITE WIRE YOU CLIPPED IN STEP #6 ABOVE)
14) IF you have headlight / dash lights you may want to hook up the backlight by using the WHITE WIRE FROM THE TACH. (it may be powered by the RED WIRE as an option).
TESTING:
Get in the car and turn the igniton part of the way, DO NOT START THE CAR JUST YET.....
SEE IF THE TACH RESETS, if it does, you are OK. (RESET MEANS GOING TO ZERO). IF it doesn't, you want to STOP and double check steps 1-14 to be sure you did them right. If it reset,
Then you are free to start it up and take a spin around the block.
ENJOY, A TACH THAT ACTUALLY WORKS, instead of a stock one that is 500-1000 RPM OFF. Mine was WILDLY INACCURATE.
I can send you some pics of the install (or point you to my website if you need more details).
So, there it is, i did it and i contributed to the net knowledge so others can do it.
Oh yeah, there's a good link here
www.bowtieracing.org/amp_pic1.jpg
which has some pictures which might help you if you need.
Good luck, and enjoy.
Brian LaRose
87 IROC Z/28; 305 TPI, 5 Speed. SCCA - class ESP
Old May 30, 2012 | 06:22 PM
johnf123's Avatar
Car: 1992 RS vert
Engine: forged 383
Transmission: a busted one for now ;)
Axle/Gears: 4th gen 3.73
Re: Tach in 87 IROC / 305 TPI
followed these, and it worked great on my 92 RS! thanks alot! one question, where does the white wire get hooked up too?
Old May 30, 2012 | 07:13 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Headlight switch so the tacho lights up when lights on
Old Jun 3, 2012 | 09:56 PM
Firebird1990's Avatar
Car: 1987 Trans Am,1989 GTA
Engine: 5.0 Tuned Port Injection, 5.7 tpi
Transmission: 700r4, 700r4
Axle/Gears: 2:73 Posi, 3:27 Borg Warner 9 Bolt
im currently hooking up aftermarket tach followed these steps but tach still doesnt work the light does so i know i got a good ground and power wire and the white wire is spilced into the red wire so all those are good but ive splice into the white wire on the negative side of the external coil with the green wire and im not getting any reading or anything for the tach wire
Old Jun 3, 2012 | 10:17 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Does the tacho actually work ?( been tested in another car )
Old Jun 3, 2012 | 10:23 PM
uh no it hasnt i bought it brand new, when you connect the green wire to the white wire on the coil do i wire all three wires back togather both ends of the white ones and the green one or ?
Old Jun 3, 2012 | 10:33 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
when you connect the green wire to the white wire on the coil do i wire all three wires back togather?
Green wire from tacho goes to white that USED to go to tacho in dash
should still only have 2 wires on Neg terminal of coil
Old Jun 3, 2012 | 11:44 PM
sorry for the confusion i did however figure it, switched to a different ground and it worked. Btw i thought the stock gauge was not suppose to work after install? Both the tach and gauge work
Old Jun 3, 2012 | 11:54 PM
BrianChevy's Avatar
Car: 1987 IROC Z/28
The stock gauge does NOT work if you cut the proper wires. I didn't want it to work any longer because it was always off by a few hundred.. Glad it worked for you.
BlueIroc-Z
Jun 9, 2019 03:22 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
