Car Alarm Gremlins
Old May 30, 2003 | 03:25 PM
'82 Beater's Avatar
Car Alarm Gremlins
My alarm has problems. The battery used to drain after a week of non-driving. I traced that to the car alarm. I disconnected the harness to the alarm box under the dash and the battery stays up now. Of course, now I have no alarm. What could be causing the drain within the alarm? Something the shop hooked up wrong or is this a problem inherent to car alarms?
Old May 31, 2003 | 02:48 PM
3gc's Avatar
3gc
Car: Z28
I would imagine that the alarm needs to use some power for it to continue to operate. I would just start the car every couple of days.
Old Jun 1, 2003 | 01:04 AM
mrbboy's Avatar
I had the same problem with my car alarm draining the battery. Most alarms now have built-in relays that can get stuck in the on position. THat causes the power drain. Also, any relays that you had to add to turn on the flashing lights, door locks and starter kill should also be checked. I just installed a new alarm and that fixed my battery drain problem. I hope this helps.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
