possible bad alt.
Old May 31, 2003 | 12:39 AM
btcamaro's Avatar
Car: 91 Camaro
Engine: 383
possible bad alt.
I was scanning my car tonight and when I go into WOT the voltage drops to 11 volts. Does this mean that my alternator is bad and that i need to replace it. During normal operation the voltage stays at 13.5 volts.
Old May 31, 2003 | 05:15 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Most likely the brushes are worn, or the brush holder is burnt or both. Average output voltage wise should be 14-15 volts a little off idle. I have rebuilt many over the years and generally when you see diminishing output as rpm's go up it's a brush issue. Rarely does the rectifier pack or voltage regulator fail. www.alternatorparts.com sells overhaul parts, and if you are moderately handy and can use a soldering iron you can service these units for a fraction of the cost of replacement. Places like NAPA generally sell service parts as well.
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
gta892000
Sep 16, 2015 12:40 AM
Slush92RS
Sep 2, 2015 08:56 PM
