Alternator wiring
Old Jun 4, 2003 | 12:39 AM
Powernxs's Avatar
Alternator wiring
I am finishing up my Haltech E6K install and working out bugs with my car. I need to know how to wire in the 3 wire plug-in on the alternator and I did a Tach test on my stock tach and now the needle resides at 7000 RPM can this be fixed or is the tach toast?
Thank You
Old Jun 4, 2003 | 05:58 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Heavy wire in rear goes to battery through a fuse link, two top plug wires the heavier of the two goes to a " key on" 12 volts. Other wire is a sense line that ties through a resistor or diode to any 12 volt key on line. www.alternatorparts.com has a free online manual with different wiring schemes for Delco alts.
eightsixseven
Dec 16, 2024 01:50 PM
db057
Sep 4, 2015 07:57 AM
g.l.mos
Aug 22, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
