distributorless engine
Old Jun 4, 2003 | 09:54 PM
eric m 91 rs's Avatar
is it possible for us to put a direct ignition on our cars, you know a coil for every plug?
Old Jun 4, 2003 | 09:58 PM
3gc's Avatar
3gc
Car: Z28
People have put LS1s in these cars before and i'm pretty sure those are like that so it is possible.
Old Jun 5, 2003 | 03:16 PM
but could we do it to make it work with our tpi
Old Jun 5, 2003 | 09:14 PM
Tyler-88's Avatar
you'd be better off putting an LT1 engine in, probably easier and way cheaper.
Old Jun 9, 2003 | 01:05 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: distributorless engine
yes. i dont recall the name of it, but there is a company that makes kits..
pretty much you can run any SBC ignition system... just make it a crank (or cam) trigger system......
Old Jun 9, 2003 | 02:04 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
yep, what dude said, got to have a trigger serup somewhere somehow for the ECM to know when to fire which cylinders off,
are you bent on doing this ? if so then why ??
there is nothing wrong with GM distributors if are in good shape. HEI was th best thing GM ever did, IMHO
trouble free high secondary voltage
Old Jun 9, 2003 | 03:05 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
best reason i can think of for wanting to do this is so you can run a LT1 intake without making a hole.... or if you wanted to run a tunnel ram or some other intake that does not have enough room for the distrib....
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
