Tested Resistance on VSS, NEED HELP
Old Jun 7, 2003 | 01:27 PM
StocRoc's Avatar
I just put a t56 transmission into my 86 Camaro and I am installing a Cable-X, which is a box that converts the electronic VSS on the t56 to a mechanical signal so I can use my stock speedo. My problem is I need to find the high side of the VSS to hook into the Cable-X, but when I test the resistance on both wires from the VSS my multi-meter doesn't show any readings at all. Please help, I want to get this thing working. How does the electronic VSS work, do I somehow need to get power to it?
Old Jun 8, 2003 | 08:42 AM
StocRoc's Avatar
any ideas, I did a search on VSS but there was nothing that helped me
Old Jun 8, 2003 | 08:05 PM
Odyssey's Avatar
If your meter doesn't show anything (make sure it's set on "Ohms") then your sensor is toast. Make sure you get a good connection though and make sure you're testing the right wires.
Old Jun 8, 2003 | 08:40 PM
StocRoc's Avatar
If I plug my meter directly into the VSS should I still get readings?
thanks for your help, I really appreciate it.
Linson
Oct 24, 2025 02:00 PM
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
RedLeader289
May 28, 2019 01:47 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
