85 LG4/L69 , alternator plug wires/voltage question
Old Jun 9, 2003 | 03:38 PM
MartinCadek's Avatar
ok my alternator has a plug going to it with two wires , and then a stud sticking out like they all do...
anyways, when installing something yesterday I broke one wire going to the plug right at the plug.
plug has a red and a black wire going to it , I broke the black one, I managed to remove the black part , crimp new wire into the connector and put the connector back in the plastic , plug it in and all was well, except it's little loose in there.
so my question is , what is the black wire in that plug used for and what voltage should go through it ?
my battery is ~14volts , the red wire has ~14 going through it , but the black one that I had to fix only has ~2v going through it , that seemed kind of strange but I didn't measure it before I broke it so I don't know if it's normal.
thanks in advance for any ideas
Old Jun 20, 2003 | 05:24 PM
83_1/2 L69's Avatar
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
Need more info:
What are the conditions when you measure 2 volts? Is the ign. key ON? Is the motor running? Is the wire plugged into the alt.?
eightsixseven
Dec 16, 2024 01:50 PM
Bert87
Aug 23, 2015 03:50 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
