87 tpi dual eletric fans how do i setup for putting fans on manually
Old Jun 10, 2003 | 06:11 PM
whytspeeddevil's Avatar
Car: 87 iroc-z ba boom!
Engine: V8 305 ( dont be fooled) =]
Transmission: TH-700R4 beefed up
hi.....i have an 87 iroc with dual electric fans and i just wanted to know how to setup the wires with a switch so i can activate the fans so they can be running constantly through out my driving? i did see something about it on the message boards but i cant open it cause i need a certain reader for it. i did how ever see one time an old post of the fan setup but its not there anymore. so if there is a diagram or some article about it or old post. please let me know or send the information in my email address. thanks again for the help.:hail: :hail: :hail: :hail:
Old Jun 11, 2003 | 06:39 AM
ctandc's Avatar
Do a search for "manual and fan and switch" and you'll find that diagram.
It's easy enough, you just use a wire splice to tap into the green/white wire on the fan relay. Run that wire to one post on a switch, run a wire from the other post on the switch to a good ground. That way, when you hit the switch it cuts the fan on by grounding the relay instead of having a live wire running to a toggle switch.
IF you have dual fans, I'm fairly certain, that if you tap into the green/white wire of the SECONDARY fan relay, when you cut the fan on, the primary will come on as well.
And as far as the reader you need, go to www.adobe.com and get the Acrobat reader for free.
HTH
Old Jun 11, 2003 | 10:59 AM
MdFormula350's Avatar
https://www.thirdgen.org/techbb2/att...postid=1175882
Old Jun 13, 2003 | 02:31 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I just tried this and only the secondary fan came on.
I have 2 switches, one to each relay since neither of my fans would come on normally.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
onefreakz
May 14, 2018 12:15 PM
Sanjay
Aug 12, 2015 03:41 PM
